MEXICOWANDERER's avatar
Jun 15, 2016
Direct From Iota Tech
"Mexicowanderer,
The DLS-90 with the IQ4 will stay in bulk mode (14.8 vdc) for 4 hours or until the high trigger point of 14.6 is reached. Whichever comes first. There is a potentiometer inside the unit that can give you up to 1 volt max increase. Please note that tampering with the potentiometer will void warranty though.
Thank You,
John W. Kehm
Technical Support Supervisor
O. 520.294.3292
F. 520.741.2837"
  • Me? Buy a SMART charger?
    Shirley you jest. The only smart device I own is a Trace 4024 and it's a laugh when it comes to returning the cells to 25.4 saturated volts within my lifetime.
    Buy an Iota. Remove the cover and the warranty coverage. Look for a pot.
    IOTA DEFINITION verbatim
    ·o·ta
    ???d?/
    noun
    noun: iota; plural noun: iotas
    1.
    the ninth letter of the Greek alphabet ( ?, ? ), transliterated as ‘i.’
    Astronomy
    the ninth star in a constellation.
    noun: Iota
    "Iota Piscium"
    2.
    an extremely small amount.
    "nothing she said seemed to make an iota of difference"
    synonyms: bit, speck, mite, scrap, shred, ounce, scintilla, atom, jot, grain, whit, trace; More
    OK so when do we get a picture that shows what knob to turn?
  • So you're a public Utility now eh ?
    BTW- I talked to the IOTA guys several years ago about tweaking a charger to use it as a 24v float across a bunch of AGM's and got the same warranty speech. They seem to tell you once they are reasonably sure you're not a knucklehead..
  • Regardless of the above pictures IOTA is a great converter for normal RV use either on-grid or off-grid.
  • THIS...
    IS WHAT SPINS, THIS!
    400-amps at 28 volts. The two lifting eyes are no joke, I had to beg the use of an engine hoist (highway robbery) to fit the alternator to the frame. Total weight engine, alternator, regulator, external rectifiers, about 415 pounds. The engine is 24 horsepower and I have a huge suction fan on the utility building. The air-cooled engine is fuel greedy so I rely almost entirely on the water cooled Kubota.
  • Jajajajajaajaa (A dar risas en Español
    Here's Something off Amazon...
    IOTA DLS-90 Converter and Charger
    by Iota
    4.8 out of 5 stars 4 customer reviews
    | 3 answered questions
    Price: $279.99
    Defaults to lower voltage when bulk E limit is reached?. Power Pole Princess use allows the use of a 30 amp converter. Start a generator and the whole world changes.
    This is for the poor guy stuck with a half dozen golf car batteries and a Clark Kent converter. There is nothing more bitter than forking out a few hundred dollars additional for the same model generator purchased a few years before. My gensets do not DARE lean on a shovel.
    Pull a plug? I'd much rather twist a timer dial.
    Wish it had external control of time duration at 14.8 volts.
    That's called pulling the plug :)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
