CA_Traveler
Apr 11, 2015Explorer III
robogobucks wrote:There is no simple answer to your question because there are so many different receivers and dish antennas.
Hi all this was very informative, but I am tech illiterate, So after I get the equipment, I have Direct at home, how do you run it into the TV's in the RV in order for it to work. I believe the RV was prep for Wingard satellite it is a 2003 Newmar
So you have to learn enough to know how to buy/use/setup your RV to use the same receiver. For years I had compatible equipment but had to change the receiver setup when the receiver was moved. Today my dish and receiver are 100% compatible. The TV is not the same but both have a HDMI cable connection and the receiver says resolution adjusted...
There is another option - Hold up your credit card to make the adjustments or purchase whatever is required for compatibility.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
