mexicanpiloto13's avatar
mexicanpiloto13
Explorer III
Dec 02, 2013
Direct TV problems-Reciever won't raise the dish
Hi All,
I had earlier asked about a problem many RVer's are facing.... especially those with MotoSat dishes. (MotoSat is out of business) Direct TV will takes away the older RCA receivers and upgrade them with a new unit, except the new unit is no longer capable of locating the satellite, and turns the whole system into a boat anchor!
Well, Direct TV finally said if I could get hold of an old RCA receiver, they would activate the card again.
So I went on EBAY and purchased the exact same model Direct TV had removed, an RCA receiver model number DRD420RE, but when hooking it up, again, it wouldn't raise the satellite dish.
I realize now, maybe sooner than later, I'm going to have to replace the entire system with a Wineguard Traveler dish for $1995.00, but in the meantime, I would like to get this up and running for a little while longer.
Any thoughts? I did make sure the receiver was programmed for a round dish, but I don't see any other pertinent set up information. All the connections seem to be made properly.
Thanks
  • Some of the earlier systems used feed back from the receiver via serial RS-232 cable. I suspect that is what you have. I might have one of the old receivers laying around from pre Nomad days. If you got a Nomad controller, it would probably solve your problem. Check eBay.
    Also could try Motosat Parts
    Dare I say the nasty word? Dish. If you would consider going with Dish you could save about $800 on a Trav'ler for Dish.
    Wingard Trav'ler 1000 - $1,167.68
    I purchased a Trav'ler 1000 last week to replace my Winegard RT4035T RoadTrip Mission in-motion antenna.
    Anyone interested in a Winegard RT4035T in-motion antenna?
  • Direct TV receiver doesn't raise the dish. That is done by a Moto Stat controller something like this.
    Moto stat
  • I am not understanding your issue, but do not doubt it.
    I have the old style 18" round dish with dual LNB that I set up for camping. I use one of the receivers that I take out of the stick home. It is a DVR type though.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
