CA_Traveler's avatar
CA_Traveler
Explorer III
Apr 06, 2014
DirecTV HR44 Problem
I took the first dry camping outing with the HR44 and ran it on the gen which meant it was turned off when not in use. About half on the power on’s resulted in a No Signal message which was resolved with a receiver reset and once with a receiver power off/on sequence.
The SWM coax connections were tight and there is no apparent reason for this problem. Since this is a new receiver my off/on experience is limited. For over 2 years there has been no problem with the HR24 receiver on SWM. I have no reason to suspect the gen and the HR44 has an external brick that supplies DC to the receiver.
Anyone else had a similar problem with their HR44?
I now have a splitter installed and next month’s trip will include the HR24 for a direct comparison.
Otherwise the HR44 is a significant improvement over the HR24. 5 channel recording, channel changing is half the time and scrolling through the guide is lighting fast. At home it’s connected via WiFi to my router for internet access for YouTube, etc, but no browser.
  • Good to know. I don’t have a mini client and the installer said that both the coax (C41) and WiFi wireless (C41W) versions are rock solid if installed correctly. The C41W and the required Video Bridge have distant restrictions from any other WiFi and that might limit installation in a RV.
  • I use an H20 in the RV, but have noticed that the H44 doesn't like surprises. When I've fiddled with the RF distribution at home sometimes the main Rx needs an orderly reset. The clients really get upset.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jul 24, 2025
