Swampman597
Mar 23, 2015Explorer
wa8yxm wrote:
Two types of converters.. 3 solutoins
2.2 In some cases the same breaker also feeds other things.. In this case <--- that's the way mine is
Find the wire that feeds the converter 120 volts (Go for the black one)...Cut or disconnect it (Disconnect is best either end)...Using the same gauge wire run a lead up to a switch/outlet type box you put nearby....Black lead on that cable goes to the breaker, or to the end of the disconnected wire (Connect properly,, Wire Nut and tape both is good) I solder and tape) <---- thank you - thats what I was considering but wasn't able to ask so eloquently..
Thanks everyone and I'll report back when its done. Youse guys are the best.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
