lenr's avatar
lenr
Explorer III
Jul 17, 2019
Disappointed in Disc Brakes
I admit, I choose that topic just to get your attention. It’s the actuator and its integration with the brake controller that leaves me disappointed. I’m very interested in hearing others’ experiences.
We had Kodiak disc brakes and a Dexter actuator installed on our new fifth wheel trailer. We’re using the integrated brake controller in our 2012 F-350. The disc brakes work so well (after break in) that I have to turn the gain down to 6.5 (out of 10) to keep the wheels from locking up on hard braking. With the gain turned down the Dexter actuator doesn’t start up until the brake controller is up to 40% on the dash bar graph. Then when it does start it’s into serious braking. So, the result is no help from the trailer on light braking and a big jerk once the brake petal is pressed into medium braking. The whole business is very disappointing, and has me wishing that I had just stuck with drum brakes.
1. Does anyone think that a different actuator would solve the problem? The Titan BrakeRite apparently has a lower start up voltage--but, it still is going to be up in the range a little, probably about 20 or 30% brake.
2. I’ve read that there is a time delay with disc brake actuators. What actuators are the fastest, in your experience? While I may be experiencing this also with the Dexter, the bigger problem seems to be not getting up to the turn on voltage.
3. Installing an after-market controller such as the Prodigy seems to be a catch-all answer. If you have found this to be a solution please explain why you think so, and how it works better.
4. What setups are you perfectly happy with: controller and actuator?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
