lenr's avatar
lenr
Explorer III
Jul 17, 2019
Disappointed in Disc Brakes
I admit, I choose that topic just to get your attention. It’s the actuator and its integration with the brake controller that leaves me disappointed. I’m very interested in hearing others’ experiences.
We had Kodiak disc brakes and a Dexter actuator installed on our new fifth wheel trailer. We’re using the integrated brake controller in our 2012 F-350. The disc brakes work so well (after break in) that I have to turn the gain down to 6.5 (out of 10) to keep the wheels from locking up on hard braking. With the gain turned down the Dexter actuator doesn’t start up until the brake controller is up to 40% on the dash bar graph. Then when it does start it’s into serious braking. So, the result is no help from the trailer on light braking and a big jerk once the brake petal is pressed into medium braking. The whole business is very disappointing, and has me wishing that I had just stuck with drum brakes.
1. Does anyone think that a different actuator would solve the problem? The Titan BrakeRite apparently has a lower start up voltage--but, it still is going to be up in the range a little, probably about 20 or 30% brake.
2. I’ve read that there is a time delay with disc brake actuators. What actuators are the fastest, in your experience? While I may be experiencing this also with the Dexter, the bigger problem seems to be not getting up to the turn on voltage.
3. Installing an after-market controller such as the Prodigy seems to be a catch-all answer. If you have found this to be a solution please explain why you think so, and how it works better.
4. What setups are you perfectly happy with: controller and actuator?
Thanks.
  • Make sure (which you probably already have done) that your system is set to hydraulic over electric, not just electric. I have the Kodiak with the Titan pump, and it works great! The best modification I've ever done to my somewhat heavy trailer.
  • I will preface by saying I am NOT using disc brakes, however do have a couple of suggestions.
    Your IBC IS far superior to the likes of a "Prodigy", replacing with aftermarket would be a step down in brake controller.
    Second, not sure when Ford added adjustment for Electric over Hydraulic brakes but you might want to check your controller menu to see if you have that setting.
    Third, some of the Ford IBCs depending on your Trim package may also have additional adjustments which may allow you to backoff the aggressiveness of the IBC.
    Fourth, if all else fails add some additional load to the electric brake wire, typically one or two electric brake magnets can be hooked up and mounted on the trailer tongue. The magnets load the IBC which may help the Hydraulic controller see proper levels. In a nutshell the Hydraulic controller may not be presenting enough load which results in too high of brake voltage.
    Fifth, don't be afraid to back the IBC down lower, if braking is too aggressive, by all means drop the IBC level down. I have to do that when changing from TT to my empty open flatbed trailer which is much lighter..
  • ppine's avatar
    ppine
    Explorer III
    I have a Draw-tite brake controller.
    Pulling a 25 foot trailer I am on number 4, sometimes 3.5.
    2002 ford one ton. It got new brakes at 125k miles.
Having RV issues? Connect with others who have been in your shoes.24,331 PostsLatest Activity: Nov 04, 2025
