janechucknicode
Sep 16, 2013Explorer
w6st wrote:
Well my son just called me from Denver, saying that his 12 volt lights are flickering dim to bright... He checked the battery, and found no water. In reading the forums it looks like the converter is trying to charge the bad battery. Question: Can you disconnect the battery and replace it while still connected to shore power? Thanks in advance. Bill
You can disconnect from the batteries, But the lack of maintenance is the real cause for no water. Hooking and un hooking from shore power has it's limits, but after 3 years my batteries have decided to lay low. Am now on a re-generating charger to rejuvenate them.
The batteries should always be checked each month at least, and filled with cooled , boiled water if needed.
Charge your batteries one at a time they work better.
My 2.875P
C
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
