BFL13
Feb 01, 2020Explorer II
So C/20 on two 100s is 40 amps? (NOPE!!!) Forget the 75 amper unless you get two more.
EDIT- C/20 is the 20 hr rate, so that is only 5 amps per 100AH!
_______________________
Looks like bite the bullet on the Gels. Toss them and get four AGMs or Flooded.
Note the DC amp draw for 120 is divide by 10, so:
Microwave- 1400w (input is higher than the watts name for output watts) so that is 140 amps. You only do that for a few minutes even with four batts.
Toaster- 900w pulls 90 amps.
TV/DVD 100w is 10 amps but then furnace comes on 10 more and you have 10 amps worth of lights on-- draw is now 30 amps so you can do that with the two Gels. But you left the laptop on! Now at 40 amps.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
