2112's avatar
2112
Explorer II
Aug 13, 2020
Dish Network Satellite Question
I have an old Dish SD 322 receiver and Winegard GM-MP1 satellite for my camper. The SD 322 was the original receiver in our home prior to upgrading to HD. At that point, I moved the 322 to the camper to watch sat TV on 1 TV. Works great, looks great. I recently installed a second TV in the bedroom, but am unable to mirror feed the second TV with this system.
Dish is telling me the MP1 in unable to mirror feed. Is this true?
Dish is telling me there are not any dishes available that will allow me to mirror feed. I need a receiver in each room. Is this true? They are pushing the hopper and joey.
I have the original SD Dish 1000 used to mirror feed my home, but without the LNBs. Dish took them back
Are LNBs available for this? Is there a way to resurrect this old dish?
Is the Dish HD 1000.2 compatible with my SD 322 receiver?
I really don't want to change my whole system, everything has been working. It would be great if I can get satellite on the second TV just by changing the dish, if possible. I'm fine with SD in the camper.
Thank you in advance for any advice provided and helping me through this.
  • 2112's avatar
    2112
    Explorer II
    Maybe I'm using the term mirroring wrong. The dish tech kept referring to it as mirroring.
    I have 1 cable connected to the dish. It goes into the camper and connects to a triplexer behind the receiver. There are 3 cables coming out of the triplexer. One goes into SAT 1 Input and the other cable goes into SAT 2 Input on the receiver. I understood him as referring to that as mirroring. One dish cable feeding two receiver inputs. I do not use the 3rd cable on the triplexer. I have TV 2 connected directly to the receiver TV 2 output.
    I can't get any signal out of SAT 2 of the triplexer. I can adjust the dish to get a signal strength of 50+ on SAT 1 but SAT 2 doesn't even recognize the dish is connected. I changed triplexers with a newer style from the house system and had no joy. He was saying my MP1 dish will not feed both outputs of the triplexer. I question that being accurate. How does the triplexer know what dish is connected to it? His next sentence was "We can upgrade you to Hopper". Throughout the whole conversation, all he wanted to do is upgrade me to Hopper.
    This use to work in my house, but with a different dish.
  • What do you mean by mirror? If watching the same channel on two TV's I believe it is more the connections than the hardware. I must admit I pounded nails for a living but I do remember taking tubes out of the TV down to the local hardware store that had a tube tester and a supply of replacements.
  • My setup as follows:
    My Xfinity STB has RCA video/L-audio/R-audio.
    From STB RCA out goes to "box with many buttons". Rear TV feed via RF (channel 3) Same channel as STB/front TV and std. def. but it works.
  • don't know what mirror feed is but you certainly can feed two TVs from one receiver running the same programs,etc.
    I have one receiver that has two receivers built in and can watch/operate individually.
    bumpy
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
