wa8yxm
Aug 30, 2014Explorer III
Ignore Hopper since you do not use it (and joey)
Yes, Dish uses UHF (and you should get it on Chan 73 OTA Analog) for TV 2, As I said Wish I could change that, on the 522 receiver...
Side note: I know that box, used to have one, This makes it easier for me.
Try lower channels, set it (in the DISH menus) as low as possible, this will reduce loss, you may also need to move up if it's RFI issue. If you can upgrade the coax to RG-6 that will help too.. El-Cheapo lowester bidder RG-59 kind of starts to show how bad it is even in the UHF band..
This is why I do not like using the park-cable line for Sat LNBs It really is bad cable.
AND MY LED LIGHTS ARE HERE per the package tracker (Well at the Landlord's house in any case) He will likely deliver tonight, tomorrow or Thursday (Since I told him no rush)
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
