SaltiDawg
Aug 31, 2014Explorer
The System Info window is a summary of your receiver's info, including Receiver Serial #, Smart Card #, etc.
In my post last night I gave you a Step by Step procedure for your model 522 receiver to change the Channel from 73 to something in the TV UHF range of channels 21 thru 69. I also linked to your receiver's Manual on-line.
You may try a higher cable channel.
What I was suggesting is to switch from the cable channels to the OTA channels and as they only go up to Channel 69, try a lower channel - one not being used locally nor adjacent to one in use locally already.
Then change your TV2 to match.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
