wa8yxm
Apr 07, 2021Explorer III
I used a PSW and had no problems.. I've heard radios around an MSW (Nasty) Ther are assorted other things however.. If the antenna is MOUNTED and you can reposition the inverter that might help.
I've also seen cases where moving the antenna if a ground mount. or the entire RV if a roof mount. made a BIG difference.
Download the Winegard sat finder app and make sure when the bullseye is centered on the screen you see SKY and not TREES.
