dougrainer
Apr 11, 2021Nomad
Good you fixed the problem. BUT, you stated it worked fine on Shore Power and not with the new Inverter. Replacing that Coax would not have fixed the problem. What Gives? The Inverter only supplies power to the Sat Receiver and has nothing to do with the Coax cables. IF the coax has indeed fixed the problem, then the 13 to 18 volt pulsed signal test I want you to do would point up a bad coax at the Sat Dish itself. My test requires you to test the output at the reciever. IF that was good, then you disconnect the Coax AT the Sat dome/dish and test for that 13 to 18 volt pulsed signal. IF you do not get that then your coax is indeed compromised. Doug
