Edd505
Apr 11, 2021Explorer
SFVdave wrote:
I believe I found the cause of the no satellites found. When we got home last night, I moved the dish receiver inside the house and set it up with no issues. This morning, I moved it back to the MH and tried it and came up with no satellites found again. I ran coax directly from the receiver to the rooftop sat dish and it worked and quickly. I then isolated the cable by running the coax from the rooftop connector to the sat dish and it woked. So I have replaced the rooftop coax from the rooftop connector going to the sat dish and it works again. So it was the rooftop cable causing the sat dish not to find the satellites and not the inverter or power supply.
Get yours straightener out you can do mine. I have to run cable in the window or no sat.
