SFVdave
Apr 12, 2021Explorer
dougrainer wrote:
Good you fixed the problem. BUT, you stated it worked fine on Shore Power and not with the new Inverter. Replacing that Coax would not have fixed the problem. What Gives? The Inverter only supplies power to the Sat Receiver and has nothing to do with the Coax cables. IF the coax has indeed fixed the problem, then the 13 to 18 volt pulsed signal test I want you to do would point up a bad coax at the Sat Dish itself. My test requires you to test the output at the reciever. IF that was good, then you disconnect the Coax AT the Sat dome/dish and test for that 13 to 18 volt pulsed signal. IF you do not get that then your coax is indeed compromised. Doug
It makes no sense. The DW doesn't want me going up on the roof, for now. So I can't do that check. But to further add to the unexplained, my friend who lives 15 miles due east of the beach campsite got a new satellite dish and Wally. He has been able to get quick setup of the satellites when at home. But when he comes out to the beach he has the same issue, "No Satellites Found". He joined us last week and we both had the same issue. I can't find any logical explanation for this. He was using shorepower at home and the generator at the beach > Used shoreline power at home and generator and inverter at the beach. But when I did the test at home, I used inverter and generator. Makes no sense. Only option left is to test voltage as you advised.
