rvluckyorwhat's avatar
Mar 25, 2015
Dishwasher water pressure issue
Ever since we bought our RV (new), we have noticed that the Fisher-Paykel dishwasher often is unable to complete a wash cycle. When it stops, it spits up a "U6" error code which indicates insufficient water pressure. I find that whenever we use our water pressure regulator outside (which is supposed to keep the pressure between 40-50 psi, the dishwasher usually stops. Without the regulator, it's hit or miss and depends on the RV park (and presumably, the pressure at the spigot).
I have been thinking about:
- buying a regulator that is set to 50-55 psi ($15)
- buying an adjustable regulator ($40, which would be worth it, but I've yet to find one with good customer reviews)
In the meantime, I called the manufacturer of our RV (it's a 2014 Thor Tuscany) and asked what the max water pressure is that they recommend. The customer service contact said don't exceed 50 psi. So maybe a more powerful or adjustable regulator isn't such a good idea after all. Next I called Fisher-Paykel and asked what pressure they require. I got a very indirect answer. They would not give me a pressure requirement (even though the error code says insufficient pressure). Instead they told me that the error I'm seeing will occur when the dishwasher can't pull 0.65 gal/min. Which sounded really low, but as an experiment, I measured flow through my kitchen sink and shower head just now with my regulator installed and they were only around 0.75 gal/min. The dishwasher has failed 5 out of 6 times that I've tried to run it at this location, meaning it ran to completion once. The other times, it would sometimes run for 10-20 minutes before failing, and sometimes would stop after 2-3 minutes. So I suppose I am at the cusp of what the dishwasher will tolerate.
I have also learned through measurement that my flow rate at my faucets doesn't seem to change regardless of whether I put the regulator at the spigot end or at the RV end of my 30 foot long hose, which kind of surprised me.
After all this, I decided to purchase a water pressure gauge so I can see what my regulator is providing, and also so that I can see what pressures seem to work and not work at various parks as we travel.
My questions are:
- Do others with Fisher Paykel washer drawers observe this problem?
- Have you found a solution?
- Do others have any other suggestions about what I might try? (besides the obvious --- "wash your dishes by hand")
Thanks!
  • Really AllegroD, 55 psi seems low? My manufacturer is telling me not to exceed 50, but now you and Myredracer are both suggesting a higher pressure.
  • Thanks Myredracer. Your post is very helpful. I had already replaced the filter yesterday (it was due anyway, although it looked OK) and checked the filter screen. It too was OK. The flow rate at my faucets was the same before and after I changed the filter. The dishwasher definitely runs better with the regulator, but some places I need one, so the pointer to a good regulator is very helpful. I ordered a pressure gauge online yesterday so when that comes in I will be able to see what my current regulator provides so I can decide then whether to get a new one.
    The dishwasher definitely runs better when I don't use the regulator (which would be an argument for getting a new one).
    However, I am seeing 1 gal/min at my faucets even with the regulator I have (I know I said 0.75 in the original post, but I since learned that my 1/2 gal bucket actually had a measuring line inside it and it was more than that to the brim), so if the DW only needs 0.65 gal/min, this would indicate that there is something wrong with the line to the DW or the DW flow sensing mechanism itself. It might be time to try to figure out how to pull the dishwasher out from my cabinetry to see if there is a hose kink or not.
  • What PSI does thor test your water lines at? 55 seems a bit low. Others had a great idea of checking your hoses and lines for kinks/blockage. Have you checked your water filter(s)? If dirty, each will reduce flow. Do you have any screens in the hoses/water intake which could be clogged?
  • Getting a "real" regulator might help esp. one with a higher flow rate like a Watts 263A. I'd also mount a pressure gauge inside somewhere, possibly near the DW and see what the pressure does in a static condition and when a valve is wide open. Those exterior inline "regulators" aren't really regulators and are flow restrictors. Try removing it and see if the DW runs any better. You can modify PEX piping using sharkbite fittings and that way you won't need any special tools. Kinked lines are always a possiblity - we had a totally kinked one in our 2014 KZ.
    Any RV should be able to run at 50 psi. I run ours at 60 psi because that's what the RVwaterfilterstore.com recommended to me. If you have any filters, check to see that they aren't plugged up and need replacing. The filter screen at the water inlet on the side of an RV can sometimes become clogged and also the check valve inside the water inlet.
  • The above is correct check the water line for kinks and check the connection to the diswaher
  • Your problem is probably simple. One of the water lines going to the Dishwasher is either partially clogged or kinked somewhere. The Dishwashers will work on either water pump or City water. ALL the Dishwasher is telling you is---I don't have the water to do the job. It does NOT measure pressure. Doug
  • We have a Fisher Paykel drawer and have never had this problem. But I only use the external water hookup to fill the tank. Normal operation is to run off the tank with the pump that's in the motorhome and it's capable of moving a lot of volume. We could have the DW and clothes washer running while someone is using the shower.
    External connections are hit or miss in terms of pressure and/or flow rates.
  • RVLucky ~ Your problem isn't pressure, it's flow rate. With the external screw on regulator your volume is seriously reduced. Think of it like a nozzle. You can have all the pressure in the world but the nozzle restricts how much water (in volume) you get through the line. The best solution (IMHO) is a whole house regulator from the Borg and install it inside your unit where the city water line comes in. They're adjustable and have plenty of volume. Plus, you won't leave it screwed to the spigot when you drive off . . .
    Just my $.02, YMMV
    Jim
  • The high volume regulators are rated at over 50 psi, which was the limit that the Thor customer service personnel recommended.
  • Get a "high flow" or high "volume" regulator like are available from Camco. They pass a lot more water through.
    Or you can get a Watts whole house regulator but the $12 versions I suggested above will work great.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
