Boon_Docker
May 11, 2016Explorer III
Mud Hole wrote:
I can find lots of 12VDC heater elements, but all are 1" NPT and won't fit into the drain hole. I did find a 120VAC 600W element that will fit in the drain hole.
***Link Removed***
What happens if I use it with 12VDC? I asked this question of an electrician a long time ago and he told me it would work, just not nearly as effective as running it on 120VAC.
Does anyone know of a 12VDC water heater element that will fit into the drain hole?
MH
Use that 600 watt element together with a 600-1000 watt inverter.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
