Boon_Docker
May 11, 2016Explorer III
Kayteg1 wrote:
You can't run 1400W inverter on excess solar that will deliver much less than 1400W.
You'd need batteries to compensate for the difference what would not make much sense.
I would simply run the inverter from main battery bank at noon (when batteries are already full charged) and even when inverter discharge the batteries to some degree, the WH will turn off after about 30 minutes, so solar will top off the batteries.
Question is how to make the system working automatically as manual monitoring and switching would be too much hassle for me.
Are we talking 1300W of solar on RV?
If so, I want to see a picture.
I think you are confused.
The discussion is about running a 600 watt element with excess power produced by the OP's 1300 watt solar.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
