BFL13
Aug 01, 2013Explorer II
Your inverter input or your converter output wires can be used as double duty for the parallel linkage between the two sets of batteries, if you twin those wires. This can be useful where the inverter or converter is mounted somewhere between the two battery banks.
Make a sketch and play (eraser required) with wiring arrangements. Likely you will see ways to make it work with less wire.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
