Second_Chance
Jun 25, 2018Explorer II
You don't say what type of construction it is - fiberglass laminate? Metal over wood frame? There are some BIG differences. I would let a pro do fiberglass laminate repair. If "stick and tin," you could get matching metal siding, remove the damaged part and check the framing, and put new metal over it.
Rob
Rob
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
