- thomasmnileExplorer
tonyclifton wrote:
I thought old retired guys were more chill than this. Do folks get this way at actual RV parks?
Sometimes, especially when the discourse is alcohol fueled. :B - tonycliftonExplorer III thought old retired guys were more chill than this. But men tend to bicker endlessly on most hobby forums I visit. I still can extract a tiny nugget of helpful information if I read between the distractions. Do folks get this way at actual RV parks?
- 2112Explorer IIOP, did any of this help?
It feels like being back in the 3rd grade here, doesn't it? - agesilausExplorer IIIMaybe we can forgo the chest beating and get back to the OP's question
- Grit_dogNavigator IIISounds like this cover yer genny is getting fire up just like the rest of them.
The best part is watching people argue both ways and not consider that the answer is still super subjective. Yet very few qualify their answer or opinion. ( I did, btw)
If a guy says I’m camping in the rainy weather for months on end and I use my generator 2 hours a day, my Recommendation would be to stick it under the truck or camper when not in use.
But occasional rain or in use while raining , pffft, fire it up in the rain.
The constant belittling by some just appears to be part of their nature…or superpower! - dieseltruckdrivExplorer II
Gdetrailer wrote:
MFL wrote:
2oldman wrote:
Gdetrailer wrote:
I can always count on you to single me out for criticism.
Maybe some of us value our equipment more and would like to keep them in good order for a much longer life?
Look at his trailer on profile page, then compare to yours. Envy can be cause for the less fortunate, to attempt to belittle the more fortunate.
Jerry
I don't "envy" anyone here but I can count on some to point out leaving $1K plus items out in all kinds of weather and bragging it never hurts it..
I rather spend less, fix things that others throw away because they abused it and use those items for a long, long time.. Yes, my stuff lasts because I care, it is the reason I have a 120 yr auto in working condition and 50 yr old antique auto that I am currently restoring :B
Making a nice dry shelter for any gen is a good idea, would rather have a dry gen with dry outlets than a rain soaked gen with wet outlets any day.. The bragger just might not wake up after touching their rain soaked gen..
I am with 2oldman on this one 100%. It is in no way abuse. The Hondas are very well protected.
I have WAY over 1000 (probably over 2000) hours on the Honda I bought new, and I have no idea how many hours the one I bought used had before I bought it, but it is approaching 1000 hours since I installed the hour meter on it. I used it for a couple of years before installing it.
If I think of it and I know the weather is going to get bad I will put them under the front overhang or under the slide. If I wake up and they are in the rain, they stay where they are. For the nervous Nancies that think I am going to die because I have my generator within eyesight of my camper, I have two CO detectors, and one of them I have verified is accurate. I know how to do that kind of stuff.
There is a reason the Hondas are worth what they cost. I have no idea how the cheaper gennies are sealed but I know what I have.
Also regarding using them when they are wet, where is the path to ground? I don't drive a ground rod for my generators. - 2oldmanExplorer II
mobeewan wrote:
A good cheap solution... until the wind starts blowing :)
I normally just tie a rope to 2 saplings and throw a 6 x 8 tarp over it in an A frame or leanto then either tie the corners to other saplings or bushes or stake them out to the ground. - mobeewanExplorerI normally just tie a rope to 2 samplings and throw a 6 x 8 tarp over it in an A frame or leanto then either tie the corners to other saplings or bushes or stake them out to the ground.
If no trees, I use a couple tent poles and stake the tarp out in an A frame. Another thing I will do is tie a rope to the center of the rear bumper and tie the other end to something near by, tie 2 ends of the tarp to the opposite ends of the bumper and stake out the other 2 corners. In all cases I make it high enough to crouch under it to put gas in, check the oil & pull start it. - 2oldmanExplorer II
bgum wrote:
They sure are. We don't get a lot of rain up here.
Things are different in different places. - bgumExplorerBring those puppies down here and you will find out you do need a cover and will begin to look for a boat.
Things are different in different places. Why abuse your equipment and it is abuse.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
