MEXICOWANDERER
Feb 20, 2016Explorer
- I have to keep in mind, Transpo products are the result of WAI China not Transpo Orlando FL.
- That DLO wire is so impressive I have adopted it replacing ANCOR or the wire furnished by genuinedealz. The source has a limited inventory and man I priced DLO through other sources and it is costly!
- Quickcable has the finest selection of battery boxes on the planet and they even have a battery venting kit with a killer decorative outside cap (white)complete with tubing, flanges, clamps, everything!
- I have a COSCO (not Costco) folding hand truck, and if I can find a source for those "stair climbing" wheels found on furniture dollies, I will adapt them to the folding "diablo (Spanish)"
- Everything is going to have a Quickcable battery box. They use the kind of unbreakable plastic that looks somewhat like plywood chip board. The 2-story will have meters and shunt sunk into the top along with coil-cord twanger connections
- Might as well go out in style
- I have gotten so weak with a bad disc and inoperable hand, that a stupid UL1-R garden tractor battery would be a challenge for me to handle
- Now you see why the 911 series voltage regulators are superior to the FR540-HD
- The 911's do not drift. 1% resistors throughout and they are double wattage rated. Even the zener is a 3-watt model, or shoot, it used to be
- But the insane-asylum grade voltage control of the OEM MoPar ECU regulator makes digital monitoring impossible
- The original voltmeter movement is so heavily dampened it is testimony that some folks think a solution to a problem is to cure the effects not the cause.
Landy, you still have my vote as the "can do, will do, did, and let's modify it and make it better" leader on this forum.
Meanwhile I keep searching for "THE" lowest-priced supplier of Meanwell power supplies. I seem to be using a lot of 36-volt models for my LED projects. A reasonably priced 500-watt model would be a blessing.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 07, 2026
