BobsYourUncle
Sep 02, 2013Nomad
I just got back from a long weekend trip.
On the way up to the lake all went well, although I did use caution and dropped a gear or two up the big hills. Kept the revs up and easy on the throttle.
On the way back I made it halfway home, this time driving normally without dropping gears on the hills and it occurred once on a long hill.
I pulled over, plugged in my code reader and same code again, P0087. I reset it and drove carefully the rest of the way home without issue.
Temperature was quite warm - in the high 80's.
I am going to change out the rubber lines by the transmission and see if that helps. But I won't know until I hitch up and go up a long steep grade towing.
Best to try the cheap stuff before getting into the more costly items.
Thanks for all the help everyone.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
