otrfun
Jul 07, 2020Explorer II
wa8yxm wrote:Ditto. Folks tend to use the term "surge protector" loosely. A "true" surge protector, as you mentioned, only protects you from voltage spikes/surges a few milliseconds long (i.e., lightning strike)---that's all it does. It does nothing to protect you from constant low/high voltage situations or wiring problems. These typically cost less than $150.
. . . But also be aware there are two types of devices called "Surge Protocters"
One is what I call a Spike supressor. I won't go into all of it but from time to time line surges can Spike the voltage eaily to a thousand or more. These "Clip" the spikes The spikes are very (like 1/60th or 1/120th of a second or less) long. But if you plug into say a 240 volt line with a 30 amp plug. No protection. or if the voltage drops to say 90 no protection
The Surge Guard I have .. well it will not pass power in either of those cases and some others as well.
Folks also use surge protector to describe the Progressive Industries series of EMS's (Electrical Management Systems). The EMS provides standard surge protection plus protection from constant low/high voltage situations and wiring problems. Big difference. These units typically cost $250-$400.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
