BFL13
Oct 18, 2014Explorer II
MEXICOWANDERER wrote:
A question from the WFCO IGNORANT if I may...
Is that not a 40 ampere ATO fuse that I see? As pointed out by westend, there is a slot above this fuse that is unoccupied. If it does take a fuse, would that fuse correctly be s 2nd 40 amp fuse? If the answer is yes, the only thing that would make sense with a single positive output point is each fuse protects each polarity connection. I'm just guessing at this, and wish to learn.
Some converters have three fuses like the PD9280 My PowerMax 100 amper has four 40s which seem to be all on the pos output, but I am not certain--all red wires anyway.
http://www.adventurerv.net/intelipower-pd9280-convertercharger-amp-charge-wizard-pi-5031.html?osCsid=pb3j5l4uhlk9mcj9m9i86amgd3
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
