valhalla360
Jun 13, 2022Navigator
mooky stinks wrote:
Ok I’ll try to give some more info. They are regular lead acid. First night they were 100% because it had been parked in my driveway plugged in for 2 weeks. I was charging for 2 hrs in the morning and 3 hrs in the evening. I did periodically shut the converter off to run a microwave but that was very limited. Probably 15 minutes total per day. I’ll have to look but I know I have a WFCO 8930/50. Trailer is 50 amp. There is a breaker that says converter. Am I right in thinking it is a separate unit?
Searched the number and that's the distribution panel, not the converter...but it says it's compatible with 55, 65 or 75 amp converters, so worst case, you should have 55amps.
With 5hrs of charging, that pretty much rules out my thought on not giving it enough time. That should definitely get it up into the mid-80% range if things are working properly.
