rtaylor0830's avatar
rtaylor0830
Do these temps sound right
I came back from the ocean last week. It was about 87 degrees outside and I towed for three hours nonstop. I took temps on the hubs as soon as I stopped and was getting around 110 on the front axel on both sides and 122 on back axels on both sides are these out of range and is it normal to have different temps on different axels
  • more important that all temps are consistent. taking temps is more for looking for something out of the ordinary.
  • Robert, those temperatures are well within the normal range.
  • Start checking your brakes/wheels on a regular basis, you will get an idea of 'normal' temps.
    Normally if all temps are relatively close you're good. You're looking for a disparity in temps to find a problem.
  • Those temperatures sound normal to me. It is in the range of the tire temps on my truck and fiver.
  • My only guess is that the forward axle is getting more air flow. But that is really a weak guess.
    Many truck weight stations now have infrared camera to take a picture of the trucks coming into the weight station. Any rims that are "Cold" indicate a brake not working. Any really high temperature reading indicates a brake that might be dragging.
    Chances are that a dragging brake would be well over 200F, while one not working would have been closer to the ambient temperature.
    My only question is how much did you use the brakes before measuring the temperature? It seems like the hubs are not much more than the outside air temp (you stated 87F). Normal running on a interstate would be about 10F - 25F warmer just because of friction in the hubs and tire flex. If you had been using the brakes a bunch, then they should have warmed the drums more - if the amperage was set high enough to have effective brake pressure.
    You can also test each brake drum with a compos. Hold the compos near the drum, have someone push the brake on manually, and the needle should point N toward the rim.
    Fred.
