redramer's avatar
redramer
Do U have Large Solar Panel Problems?
Looking to replace small 12v PV panels with 60 cell 24v panels that are often in the 3' x 5' size.
Has anyone had problems with large panels committing suicide from bouncing around, flexing too much, weak frames, too much heat on rubber roof... anything?
thanks
  • redramer wrote:
    .. maybe need some sort of foam/rubber support there,
    No more than you need slideout supports.
  • Thanks for all the responses and pics.
    I was thinking there'd be an issue with sagging towards the centre of the array after all these bumps and maybe need some sort of foam/rubber support there, BUT looks like I'm good to go.
    Happy trails
    dennis
  • 327 watt panels. Added a 4th one after this pic was taken.
  • Three 100 watt WindyNation panels...no problems....glued and screwed....and I never turn down driving into a USFS, BLM etc. campground via a dirt road. About 40 by 27.
  • Follow manufacturers recommendations on install and I cant see why you would have an issue. Theres hundreds and thousands of rv's on the roads today with large 150-200W panels that haven't fallen off. Good wood screws, plenty of Dicor and solid mounting brackets then hit the road. Good luck with the project.
  • I'm running 315w panels. No problems. They are made to withstand hurricanes and hailstorms.
  • No problems since I installed them 2 255 watt. I have 6 brackets on each one.
    Brackets 6 each panel
  • Almost 80,000 miles on six 135w Kyocera panels including 3 trips to Alaska and not a single issue. Panels are 59x23.
  • The 3X5 panel on the Sahara was there when I bought it. Near as I can figure from the Mx paperwork, it was installed in 2007.
    I added another one in the spring this year. Looks good so far.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
