DAS26miles
Jul 04, 2015Explorer II
I guess mine when it does arrive having a slide on each slide won't make too much difference in leveling.
Many of the campsites we frequent are backins and the rears are much lower than the fronts. To heed the warning of keeping the rear tires on the ground because that is where the parking brakes are, do you use ramps on the rear? I understand raising too high can cause the leveler pistons to tweak and then not retract, true?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
