westend
Jun 22, 2014Explorer
Assuming 8' width of trailer and 6" rise in the middle, the angle of the roof would be about 7 degrees. If your mounts are all the same height, the 7 degrees would be subtracted when tilt angle is referenced to the top of the mounts.
FWIW, i have a feeling that when using small amounts of solar (less than a KW), having Winter tilt angle off by a few degrees is not that meaningful in the greater scope of things. First, your batteries are going to be fully charged after two days in sun and the difference of a couple of degrees is going to be the difference of a few minutes of charging. I'm a big believer in getting every watt possible and not wasting a ma but storage considerations are different than daily use.
