valhalla360
Feb 02, 2019Navigator
If it makes you feel good, go for it...but it doesn't do anything.
There are plenty of bacteria and enzymes already present. As long as the solids don't dry out, they will break down just as fast with no additives.
A little water so solids don't turn to cement on the bottom isn't a bad idea but if you drained and flushed, that isn't even needed.
If you have odor issues, most likely problem is a blocked vent. Fix the problem, don't just add perfume to cover it up.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
