valhalla360
Oct 11, 2018Navigator
MEXICOWANDERER wrote:
Especially when armed with a degree in chemistry.
The idea is to remove alcohol from gasoline since there is interest in doing it in the interests of small engine vulnerability.
RAcor makes one of the better units.
If you have a bad fuel source, filter before fueling and don't leave fuel in the small engine if not using frequently.
Otherwise, it's mostly myth that ethanol hurts small engines. This was an issue when ethanol 1st started to be used but it's been a long time since engines haven't been designed to accommodate it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
