bighatnohorse
Oct 11, 2018Explorer II
valhalla360 wrote:
If you have a bad fuel source, filter before fueling and don't leave fuel in the small engine if not using frequently.
Otherwise, it's mostly myth that ethanol hurts small engines. This was an issue when ethanol 1st started to be used but it's been a long time since engines haven't been designed to accommodate it.
It is a persistent myth. It's been 15 years or more since I had a small engine fail due to the use of ethanol content.
I use Top Tier premium gasoline in small engines and have one engine that sat for two years without use and it still started and ran.
I simply have not experienced the "old gas" problems that others have had.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
