Chum_lee
Oct 15, 2018Explorer
MEXICOWANDERER wrote:
How did this evolve into this abstract?
It has everything to do with extracting alcohol from petroleum distillate and zero to do with pumping water. Down here I do not give a ratzass about alcohol because it does not exist.
The exercise is for folks wishing to remove alcohol from gasohol. The extraction method uses purposefully added water then gravity draining the extraction water.
The folks wish to do it. I wish to extract water from fuel. A while different ball game for different reason using a different method and no alcohol.
This discussion has nothing to do with how I do things for a totally different reason.
Calm down MEX. If you don't like the discussion, no one is forcing you to read the replies or continue with it here. I suggest you ask the moderator to close the thread. You could then take your grade school science fair phase separation experiment on the road. I suggest you start with Youtube or Barnum and Baily Circus. There you'll find a lot of wide eyed kids who won't ask tough (real world) questions and your labor intensive solution doesn't have to work economically. Don't quit your day job and as always, keep your sense of humor!
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
