Yá'át'ééh; (Hello) I've posted this on a couple of other forums a few months ago and only found 1 or 2 RV owners with similar setups. Hoping there may be some on here. Keystone has modified ...
If it is like my Class C, there are two levers and another inlet for winterizing. I attach a hose to the winterize inlet and start the pump to suck water out of the jug, then switch to fill position and the pump continues to pump water out of the 5 gallon jug in to the FW tank. Works great, much easier than trying to pour water into the gravity feed fill inlet I had on my TT.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
