milo
Jun 04, 2014Explorer II
Docking Station
Yá'át'ééh; (Hello)     I've posted this on a couple of other forums a few months ago and only found 1 or 2 RV owners with similar setups. Hoping there may be some on here.       Keystone has modified ...
RangerEZ wrote:That's exactly what you want to use. Add a longer hose (if needed) to that bypass line and drop it into your 5 gal water jug (or bucket, or...) instead of the anti-freeze jug. Turn your outside valve to "tank fill", and then turn your water pump on. The pump will suck water from the jug/bucket and pump it into the lines (just like winterizing), but the water will then continue into your tank.
Regarding the winterize-intake, mine does not have this at all. I add RV antifreeze at the water pump inside the camper, through a bypass and line that comes off it. I guess I'm not understanding this idea.
