dalej
Dec 31, 2022Explorer
pianotuna wrote:
Hi,
I installed a soft start. I found it did little for me. I much preferred the results from the autoformer.
200 amps of LI and a 2kw inverter. But the battery management system (bms) will limit you to 200 amps max. One solution is to add another battery.
Battleborn, for example, does a 2C surge for 30 seconds, but only 1/2 second for higher loads.
What li batteries do you have? If you rolled your own, what bms is being used?
I have never read of using an autoformer with an inverter. Can you expound a little
