ScottG
Jul 18, 2017Nomad
marcsbigfoot20b27 wrote:
I have 2 fantastic fans from 2000.
All measurements with clamp on ammeter at the converter wire/fuse for each fan....converter was on with 1 new AGM 12 volt battery fully charged.
Front bedroom fan with temp control, bulb style. 4 amp fuse, 25 watt motor/5000RST
Low 0.8 amps
Med 1.3 amps
High 1.8 amps
Rear fan no temp ctrl, 6 amp fuse, 36 watt motor/400R
Low 0.8 amps
Med 1.1 amps
High 1.5 amps
I have no idea why the lower wattage motor is pulling more amps except that voltage drop must be in play since the rear fan is only a few feet from converter and the bedroom is a 20 foot wire run.
So you must have the older, black motors?
take care of them, the new replacements suck.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
