time2roll
Sep 16, 2013Nomad
Terryallan wrote:dougrainer wrote:
The largest is 15k. If your RV is longer than 25 foot, a 15k will not be able to keep up in temps above 90 degrees and hi humidity. Doug
Really? My 13.5, on my 29' TT, does a great job in the high heat, and humidity of a Myrtle Beach July day. (read 80% humidity, and 100+ degree F) As long as the doors aren't opening, and closing every 2 minutes, and in truth. The main door is always open, with the screen door shut. It has plastic sheeting covering the screen. Maybe it's the superior insulation values of the AZDEL construction.
That is nice for you. Some are actually well installed. Most of us have inadequate ducting, air leaks into the ceiling, poorly sealed plenum and less general insulation. No way does my 13.5 keep up on a 100+ day (26' RV) and that is dry heat here.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
