TexasRedNeck
Sep 16, 2013Explorer
WOW. I opened a can of worms. For the record it is a 2 month old 42 ft fifth wheel and has 2 ACs, a 15K in the main area and a 13,500 in the master (it is a bunk house model) The 13,500 cools the master like there is no tomorrow when I set in on dump. Both units are ducted in the duct work. Granted I'm one of those people that aren't happy if I can't acheive 72 degrees inside no matter how hot it gets. No offense to anyone outside of Texas, but unless you've been here in the summer, your reality may be a bit off (OK, some southern Louisiana and Florida folks may get a pass)
I know all the rhetoric about 20 degree drop, yadi yadi, but if you have enough money you can get square baseballs, right? the service is 50 amp and a few extra amps won't kill the system.
I am going to have the 15K unit checked out since I don't percieve the temp drop that I think it should have (only comparing the temp of the air coming out of the unit), but it may be because the incoming air is warmer since the kitchen/living area is so much larger than the master area.
I love this forum and appreciate all the comments, input and feedback, even if you think I'm crazy for wanting it 72 inside when it is 100+ outside.
Of course the other option is a third AC, but the simple answer would seem to be a larger main unit.
By the way, what is a basement AC? Is it like a ductless mini split for RVs? Never heard of that.
Oh and the duct leakage may be a valid concern ( I am amazed at the workmanship - or the lack therof -for 50K) however I'm commenting on the ability to cool the main area when dumped not ducted.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
