- Corkey05Explorerkmbelt wrote: Yeah, ... it's hard to validate claims, but the Penguin ll is on the same path. They don't give BTU figures, but call it a High Capacity. It seems the gain is in more efficient compressors and fan motors, plus improved air flow. Lets face it, the roof ac's we know are all on the poor end of efficiency, so improvements are inevitable.Corkey05 wrote:
 Atwood makes both 16k and 18k for RV's.
 Website
 Brochure
 Here is information from the website.
 "Air Command is the QUIETEST, MOST EFFICIENT air conditioner in its class, offering 16K or 18K BTU equivalent performance... THE LATEST TECHNOLOGY using the LEAST AMOUNT OF ENERGY."
 I'm not buying it, if the technology worked, all manufacturers would have something similar. Probably a 15k that can under certain circumstances can perform better. Once the stars align, sky is clear, and he!! freezes over for optimal performance.
 Penguin ll
 Believe me I'm not advocating either of these units, just passing on what's out there.
 Website
 Brochure
 Yes, but I have NOT seen such a unit and Atwood just entered the AC field. Rememeber what happened with Carrier. I would NOT trust that they actually put out 16 and 18 BTU's in hot climates. I just downloaded the Atwood spec sheet for BOTH and they state 13.5 and 15, NOT anything higher. Doug
- MiPaJacksExplorerWe got a small 120v window unit, that I hang in the bedroom window when additional A/C is needed. It is hard to keep things cool with our high temps.
 Website
 Brochure
- midnightsadieExplorer III think two ac would be better than a bigger one . two units gives you 30k of cooling.
- filthy_beastExplorerMy only contribution would be to say, check the supply wiring to see of it is big enough to handle the extra power needed for a larger AC.
- otrfunExplorer IITexasRedNeck wrote: Don't know if such a beast exists for RV's. I do know that residential,window-type A/C's larger than 14,500-15,000 BTU typically require 220 volts to operate. Just something to consider.
 Curious, at 100 degrees the 15,000 struggles to keep up at times. Does anyone make a rooftop AC larger than 15,000? Say , like a 17,000? I have not been able to find one if they do.
 Thanks as always
- Corkey05Explorer
- bywaysExplorerI haven't heard of any 17k A/C's, but most people will simply add another AC boosting you to 30,000 btu. Other, more practical measures might include screening, slide toppers, window insulating curtains/shades, and tinting. Perhaps in a more permanent setting one might take advantage of an RV well-positioned under trees or other shade producing structures. Even so, at 100 degrees the general rule is start early (like at night) and low (as in the thermostat setting). It won't keep up, but it does help.
 Some people have added (very nicely) a well placed window A/C which is powered off the 20 amp receptacle on the pedestal. I guess it's just a matter of how bad one wants to stay cool.
- The largest is 15k. If your RV is longer than 25 foot, a 15k will not be able to keep up in temps above 90 degrees and hi humidity. Doug
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
