Hiker_01
Jul 15, 2015Explorer
In simple laymen's terms - antenna gain is a measurement of increased signal strength compared to a reference antenna that transmits equally in all directions (a sphere) at a specified distance. Total transmission power is never changed, only the pattern in which it is distributed. A gain of 0 (zero) would mean that at the same distance from either antenna, the received signal strength is the same. A 3 db gain means the signal strength at the receiving end is twice as strong as from the reference antenna. A 6 db gain is 4 times (3db + 3db = double x double; it's a logarithmic thing). A negative number means the signal strength at the receiver end is less than a reference antenna.
Now, the gain in reception comes at a price, and the price is you are limiting your transmission footprint. In most cases this is not an issue as the transmission usually becomes a flattened sphere, so you aren't transmitting up in the sky or down to the earth as much but out to the sides. A directional antenna gets far more gain, but then it will only transmit or receive from specific directions.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
