MEXICOWANDERER
Aug 01, 2015Explorer
I picked up a wool robe. Impervious to acid.
Do a standard 14.4 volt charge on the battery then let it sit a couple of days. Resting voltage should be 13.15 or higher or the battery needs conditioning.
DEKA is an OK brand IMHO. Carefully wrap and store the hydrometer. Use the 1% of total 20 amp hour rating to determine full charge at 14.4 volts. 220 amp hours, 2.2 amperes or less @ 14.4 volts. Maintain (float @ 13.6 volts).
Take care of your Megawatt! This battery is going to make the Mega in need of it's own athletic supporter. Fresh, cool air to the MW.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
