pianotuna
Sep 05, 2015Nomad III
Hi Niner,
The thicker the plate the slower the recharge.
I can hardly believe the difference with the telecom batteries. As an experiment I ran the fridge on 120 volts while trundling down the road. Duty cycle is 2:3 on the absorption unit. 325 watts. After 4 hours the batteries appeared to be fully charged.
Then I turned the fridge to the 12 volt setting which draws 30 amps. I came back to the RV 90 minutes later and voltage was still excellent.
I reset the fridge to propane and drove for about 20 minutes at highway speeds (47 mph) and 10 minutes of city driving.
When I plugged in--the Magnum charger went to float at about 7 amps. Part of that was the 'house' loads.
I am FLOORED at how fast the agm's recharge. Voltage from alternator started at 14 and as the day warmed up ended at 13.3.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
