landyacht318
Sep 05, 2015Explorer
Well, as long as you drive the Toureg long enough for amps to taper to 0.5% of capacity.
If it only accepts 21 amps maximum from the megawatt at 14.4v, it will only accept 21 amps from your Alpha and Omega alternator at 14.4v and that is only if the voltage drop on the cabling to your trailer is thick enough to support that 14.4 reaching the distant Telecom AGM.
Can't argue with a 125$ 150AH AGM though. I spent over $300 for 90AH, but it will suck 100 amps from my alternator, when needed and available.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
