MEXICOWANDERER
Sep 14, 2015Explorer
"Doctor! Doctor! Why Isn't He Breathing?"
"Quick! Take His Temperature!"
I would not even ATTEMPT to manage a VRB without an amp hour meter. A real one, connected exclusively to battery negative. Use kWh to establish a Charge Efficiency Ratio percentile, then use ampere hours returned as well as algorithm percentage I at value E.
Now most will moan, cross an amp hour meter off the list, then go on to complain how unnecessary all this is. The entire 5 minutes of work it takes to set it all up. It does not take a genius to set this up. But it takes a modicum of EFFORT. Oh gee look -14 amp hours. Wonder if my battery is charged. yeah "Take the cube of voltage and divide it by estimated ampere hours times two after a two hour wait and this will get you in the ballpark". Just do not blame your battery...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
