NinerBikes
Sep 14, 2015Explorer
NinerBikes wrote:
Arrived today, after 2 days, OCV 12.91V.
Ran about 14 amps out of it in 2 hours, the Travel trailer with LED's and a 2 amp sucking TV just doesn't draw too much, had to turn fans on to pull some amps.
Shut draw off and put charger on at 1:30 PM, pulled 19 Amps charge rate from the start, at about 1:40PM.
Video link when first starting showing amp draw and voltage at start.
6.85A charge rate 2:40PM
4.95A charge rate 2:50PM
3.17A charge rate 3:00PM
2.55A charge rate 3:05PM
1.96A charge rate 3:10PM
1.68A charge rate 3:20PM
1:48A charge rate 3:24PM
1:44A charge rate 3:25PM
1:36A charge rate 3:33PM
Video at the end, at 3:30 pm
At 3:43, with being off the charger, voltage measured 13.44V OCV. It was charged to 14.40V showing at the battery terminals with the digital Multi Meter when turned off at 3:33 PM.
No matter how you do it, getting the last 10% of top charge back in these things takes it's sweet, slow time doing so, you just can't force the battery chemistry to do something it doesn't want to do, it just takes it's sweet Mary Anne time getting top charged.
For reference, from the last time... Voltage is a bit lower this time for setting on the MegaWatt, so it might be a little slower.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
