NinerBikes
Sep 27, 2015Explorer
SCVJeff wrote:NinerBikes wrote:it may also be a phantom. Do you have a Zero button on the Amp Clamp ? With currents that low I think I would opt for looping through the DVM
Well, the Amp clamp of mine confirmed that the RC Watt / Amp meter is accurate enough down to lower milliamps. Clamp meter shows. .07Amp flowing to the battery during 13.5V maintenance charge voltage, and the RC Amp /watt meter shows .13 Amp flowing to the battery, both metering at the same time.
.06
With nothing hooked up to the RC watt meter, and the Mega watt turned on, the RC meter shows .06 amps, with no load at all... I don't know what or why this is showing such flow, with nothing there, but it is what it is.
Yes, amp clamp does have a zero out feature, I have verified this reading 5 or 6 times now... I always zero out, and get wire as very close to center in the clamp opening as possible, to minimize variance.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
