ktmrfs
Jul 07, 2021Explorer III
One very important element of keeping reasonable battery life is making sure the charging profile is temperature compensated. Which means the charger needs a way of measuring battery case temperature with some reasonable accuracy.
typical float voltage for a flooded lead acid is about 13.6V @ 20C (room temp) but decreases 30m/C so at 40 C (100f) it is down to 13.0V, at 50C (122f) around 12.6
Same thing for bulk charge rates
So a charger that doesn't account for battery temp will be overcharging a battery at high temperatures.
if the battery is just sitting not being charged a few weeks, even a month or so of high temps isn't going to do much if any damage or reduce life significantly. Long term high temps then battery life goes down no matter what you do about charging. One of those things than helps us stay alive, most chemical reactions have a positive temperature coefficient.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
